VideoHelp.com Forum
  1. Member rhegedus's Avatar
    Hello capturers!
    I'm asking this question because I know I'll get impartial advice from you, which I wouldn't get from a salesperson.
    I'm currently using a standard scart to 3-jack gold plated AV lead to capture from VHS to Canopus ADVC-100. Would there be any benefit to capture quality by using scart to s-video/line-in?
    Best wishes,
    Rob
  2. If your VCR has S-video out, I would definitely use it. You should notice a difference in terms of interference and color.
    If your VCR is not s-video compatible quality will DECREASE not increase.
    And you may get a black and white picture.
    Fozzee
  4. Would a VCR have S-video out but not be S-video compatible ??
    Hi
    Where does it say he DOES have s-video out on his VCR????
    My comment was aimed at his AV(Scart) to s-video connection.
    Fozzee
  6. Member rhegedus's Avatar
    Calrification:
    The VCR only has scart output. I am using a scart adapter that has the standard L+R audio sockets, a video socket and a s-video socket. The Canopus has the same sockets.
    The audio is already sorted, so should I use:
    scart:video out ==========> video in
    or
    scart-video out =========> s-video in
    Many thanks for your time on this matter.
    Rob
    I have EXACTLY the same setup.
    If your VCR does not have a seperate s-video connection it is 99% certain of being INCOMPATIBLE with s-video.
    I tried to run the scart to s-video setup and the colour kept going funny.
    I changed to composite or video phono (whatever its called in your neck of the woods) and haven't looked back :P
    Fozzee
  8. Member rhegedus's Avatar
    I'm beginning to think the same way....whenever I capture using s-video, I get a wierd 'hatched' effect, as if there's a net curtain over the minitor. I know the lead works OK because output to a TV from my TV-out card is crystal clear.
    My VCR must not be up to to job. Ho hum...
    Thanks for your help,
    Rob
  1. IMGBurn no lead-in with +R discs
    By samijubal in forum DVD & Blu-ray Writers
    Last Post: 17th Sep 2010, 14:50
  2. Question about 5 meter Audio-Video Lead
    By VEBouto in forum Newbie / General discussions
    Last Post: 2nd Nov 2009, 21:15
  3. Can an S-VIDEO lead send a 16:9 pixel aspect ratio
    By kevthedrummer in forum Newbie / General discussions
    Last Post: 21st Jun 2009, 10:02
  4. Replies: 0
    Last Post: 7th Jan 2009, 05:27
  5. jvc gz mg505 av lead
    By merray in forum Newbie / General discussions
    Last Post: 20th Dec 2008, 04:08
