VideoHelp.com Forum
  1. I would like to get your recommendations for a progressive scan DVD player which can be made region free and, which can play DVD-R and DVD-RW disks made by a Pioneer A04 DVD burner. I use TMPGEnc for mpg encoding and use DVD WorkShop for authoring and burning. Thanks in advance.
  2. Член BJ_M's Avatar
    This will play any disk of any sort you put into it .. (also known as the Malata DVD-N996) $379.00 CND ($245.00 US)
    JATON PSD7611 Progressive Scan Multi-region Dvd Player Plays Region 1 to 6 DVDs
    BUILT IN CONVERTER: NO NTSC PAL CONVERTER REQUIRED TO PLAY PAL DVDS ON A NTSC TV
    Jaton psd7611k Progressive Scan Multi-region DVD Player is the best deal in DVD players on the market today. The Jaton Multiregion Progressive scan DVD Incorporates features that are only found on machines costing hundreds of dollars more such as , NTSC/PAL compatibility, DVD /CD/ VCD playback
    The Jaton PSD-7611K Progressive scan Multi-region DVD PLAYER provides you with superior video and audio quality with more than 525 lines of horizontal resolution,( 625 PAL) Dolby Digital® surround sound , DTS , BUILT IN AC3 Decoder, Built in NTSC PAL CONVERTER, REGIONFREE Multiregion DVD player OPERATION , Karaoke and also includes such great features as, still, step, fast forward, up to 8 languages , 32 subtitles, multi-angle, search by title and more.
    jaton psd7611 Progressive scan Multiregion DVD Player FEATURES
    Dolby Digital® (AC-3) Out, BUILT IN AC3 /DTS DECODER
    delivers crisp, theater-like sound using six discrete channels of audio. Individual channels are provided for Left front, Center, Right front, Left surround, Right surround and Subwoofer.
    96kHz/24-bit D/A Converter
    Designed to maximize DVD audio performance and enjoyment, Jaton DVD players are equipped with a 96kHz/24-bit DAC. This advanced audio DAC can handle super-fidelity 96kHZ/24-bit sound, the highest level of audio quality in the DVD format
    NTSC/PAL OUTPUT
    The Jaton Progressive scan Multi-region DVD Player will output in both NTSC and Pal Formats WITHOUT A NTSC/PAL CONVERTER!!!!!
    Plays DVDs from all regions, Selectable from 0 (Multi-region) to 8. Default 0
    Multivoltage
    The Jaton PSD-7611 Progressive Scan Multi-region DVD Player operates on voltages between 100 and 230 VAC
    MP3 Playback
    The Jaton Multi-region DVD Player has the ability to play back Mp3 format cd's. This allow you to store over 600 minutes of cd quality music on a single cd. T Supports CDR and CDRW Discs, VBR and Bitrates from 24 to 300
    Variable Aspect Ratios
    The jaton Multi-region Progressive scan DVD PLAYER will output video in 4:3, letterbox and 16:9 aspect ratios. Also the expert menu allows xy and pan adjustments to fine tune the picture
    Audio Streams
    DVD Has the ability to hold a maximum of eight audio streams on a single disc. This enhanced capacity allows Hollywood Studios to include up to eight different language tracks providing added versatility in multi-language applications.
    Camera Angles
    Scenes that make up a movie may be shot from multiple camera angles, each providing a unique perspective of the program. DVD will allow, at the director's discretion, up to nine different camera angles to be recorded on a disc, enabling the viewer to select the angle they desire. This option will add interactivity to movies, sporting events and instructional videos.
    Multi-Language
    This feature allows up to eight different audio tracks to be mastered on a single DVD The user than can select the language track that suits their preferences
    Includes
    Remote Control
    Batterys
    Composite (rca) audio Video Cable
    Advanced functions
    TRUE HARDWARE PROGRESSIVE SCAN Using the Mediamatics Pantera 2 NDV8501B2 Chip
    expert and common user menus
    Built In NTSC PAL converter
    Selectable NTSC OR PAL OUTPUT
    FULL Advanced features operation in Multi-region
    Incremental Zoom Control UP TO PIXEL LEVEL
    x-y scaling
    Pan Adjustments
    Color Brightness
    FRAME STEP PAUSE
    2, 4, 20 x FF /RR
    MP3 Mode, Long file name support, Note: MP3 Playback does not support folders
    CDR and CDRW support
    Default Multi-region, Also region selectable for smart discs using two keypresses only,
    17 SUBTITLE LANGUAGES
    Karaoke..DOES NOT SUPPORT CD-G
    Plays DVD-R DVD-rw
    cd, svcd, vcd Mp3 , cdr and cdrw compatible
    OUTPUTS
    Optical output
    1 SPDIF Coax ) digital audio output
    1 pair of stereo audio output (Down-mixing audio output)
    Dolby AC-3 six audio channel output (1 pair of main audio output, 1 pair of surround audio output, 1 center audio output and 1 subwoofer audio output)
    1 composite video output and 1 s-video output
    component video out
    VIDEO RESOLUTION
    525 LINES NTSC
    625 LINES PAL
    5 VIDEO FILTER SELECTIONS
    Interlaced Video Mode Selections
    CVBS y C Cvbs
    CVBS Y CB Cr
    CVBS G B R
    CVBS G+Sync B R
    Progressive Video Mode Selections
    NONE Y Pb Pr
    Y G B R
    Y Y Pb Pr
    SYNC G B R
    Y G+SYNC B R
    SYNC G+SYNC B R
    AUDIO SETUP SELECTIONS
    Speaker setup
    Bass Cutoff
    Dynamic Range
    Decoder Setup
    CDDA S/PDIF Bypass
    Digital Audio Setup
    COMPLIANCY
    MPEG-1 and MPEG-2 video and audio decode
    Backward compatible with CDDA, VCD1.1/2.0/3.0, MP3 and SVCD
    supports CDR and CDRW discs
    Karaoke Features,
    Karaoke echo effect
    Two Microphone Inputs with level controls Does not support CD-G
    WARRANTY
    COMES WITH 1 YEAR PARTS LABOR WARRANTY
  3. Член BJ_M's Avatar
    http://www.avdeals.ca/dvdplayers/jaton_psd7611k.htm here is where u can get them but we bought some in a local shop ..
    Hello; BJ
    Hello; will it play Video Avi and Divx formats downloaded from the Interenet and burned to CD-R I download allot of movies from Imesh and Kaza in these formats?
    TIA!
    William
    The Name Of The Game = SHARE SHARE SHARE
    I have a 996 and a 104 burner. The 996 does have one quirk. It will not play DVD-R's encoded from a DV source on any DVD-R media. Believe me, I have tried at least 10 different media brands. It is really strange. The same discs play on other DVD-R compatible players.
    The 996 WILL play DV sourced burns on Memorex DVD-RW's, and will play DVD-Rs using just about any media if the source is a DVD movie backup.
  6. Член BJ_M's Avatar
    Originally Posted by wwmw
    Hello; BJ
    TIA!
    William
    no player can do this really...
    its whats your pc video out is going to be used for though ...
    Hello; BJ
    Yes! thats what I'm doing now but, the only hang up is when someone is watching a movie on the TV, I can't be on my computer. I have the NIVIDA MX 4-200 video card with Twinview. and what show up on my PC monitor is whats on the TV in the Livingroom GRRRR
    TIA!
    William
  1. Will region free DVD play on a PAL DVD player?
    By perceptionist in forum DVD Ripping
    Last Post: 23rd Sep 2011, 19:56
  2. region free dvd player help
    By captgeobob in forum Newbie / General discussions
    Last Post: 19th Dec 2009, 19:31
  3. Do laptop dvd drives play in progressive scan?
    By ieh4f in forum Newbie / General discussions
    Last Post: 29th May 2008, 19:36
  4. Can't play PAL dvds on my region free player anymore
    By bubblefaerie in forum DVD & Blu-ray Players
    Last Post: 12th May 2008, 09:51
  5. Phlips DVP5982 Divx Player Progressive Scan issue
    By imakshar in forum Newbie / General discussions
    Last Post: 9th Jun 2007, 10:59
