VideoHelp.com Forum
  1. Hello
    I have a problem. I want to make a VCD with subtitles. I did as it has been told in DiVx2VCD guide. The problem is when I add subtitles (.ssa)
    they don't have Central Europe Language support. So some letters are not
    displayed right way.
    Any suggestions?
    Please help!
  2. tryo to find the srttossa program, with this program you can choose a font with the right characterset.
    srttossa.zip can found on doom9 and http://www.divx-digest.tv/software/s...e/SRTtoSSA.zip
    I hope this is what you mean, iam dutch so try not to read the english like a teacher
    Peter
  3. Try to change some setting in your SSA file.
    [V4 Styles]
    Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, TertiaryColour, BackColour, Bold,Italic, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding
    Style: Default,arial,17,65535,65535,65535,0,-1,0,1,1,0,2,8,8,8,0,1
    You better change the last digit (Encoding) from 0 to 1 in Style section or change fontname if the endoding-digit-change doesn't work.
    I got the similar problem before. After changing the encoding it worked.
  1. Subtitle problems using convertxtodvd
    By gtorres001 in forum Authoring (DVD)
    Last Post: 3rd Mar 2012, 01:36
  2. Subtitle problems
    By Mrs Cee in forum Newbie / General discussions
    Last Post: 8th Sep 2010, 18:09
  3. Problems with Subtitle Workshop
    By Maurob67 in forum Subtitle
    Last Post: 7th Jun 2010, 02:42
  4. Subtitle problems
    By neroman00 in forum Subtitle
    Last Post: 30th Dec 2009, 03:15
  5. Subtitle problems
    By artistguy68 in forum ffmpegX general discussion
    Last Post: 27th Jan 2008, 19:40
