Hello
I have a problem. I want to make a VCD with subtitles. I did as it has been told in DiVx2VCD guide. The problem is when I add subtitles (.ssa)
they don't have Central Europe Language support. So some letters are not
displayed right way.
Any suggestions?
Please help!
Thread: Subtitle problems
Hey, Rogy,
I have the same problem with serbian letters. Actually i have problem with 2 letters only. I am too trying to find what's going to fix this problem.
Where are you from?
Try to change some setting in your SSA file.
[V4 Styles]
Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, TertiaryColour, BackColour, Bold,Italic, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding
Style: Default,arial,17,65535,65535,65535,0,-1,0,1,1,0,2,8,8,8,0,1
You better change the last digit (Encoding) from 0 to 1 in Style section or change fontname if the endoding-digit-change doesn't work.
I got the similar problem before. After changing the encoding it worked.
This is an excellent advice!! Thanks hxc3634!! :P
This is my STYLE line in .ssa subtitle file
Style: Default,Arial,22,16777215,0,16777215,0,-1,0,2,2,2,20,20,10,0,1
Tanevski: just change the last digit from 0 to 1 just like hxc3634 said!
I am from Slovenia and I had problem
with the letter "č" (ascii code 159). I have tested it and it's OK.
Thanks again!
I have antoher problem.
Sometimes TmpgEnc does not recognize .vdr file, which is created
with VirtualDub, when I start frameserver.
What should I do?
Remark:
I see that the letter I had problem with is displayed totaly
wrong on this forum. But the ascii code is right.
Rogy
Subtitle problems using convertxtodvd
By gtorres001 in forum Authoring (DVD)Replies: 41Last Post: 3rd Mar 2012, 01:36 -
Subtitle problems
By Mrs Cee in forum Newbie / General discussionsReplies: 7Last Post: 8th Sep 2010, 18:09 -
Subtitle problems
By neroman00 in forum SubtitleReplies: 1Last Post: 30th Dec 2009, 03:15 -
Problems with Subtitle Workshop
By Jomapil in forum Newbie / General discussionsReplies: 2Last Post: 20th Jan 2009, 15:17 -
Subtitle problems
By artistguy68 in forum ffmpegX general discussionReplies: 6Last Post: 27th Jan 2008, 19:40
