VideoHelp.com Forum
Closed Thread
  1. I am trying to make a photo CD with...
    1. Digital Stills
    2. Short movies (avi's) (from my Canon V3/S230)
    3. Background music
    Nero lets me make a VCD or SVCD with digital stills and short movies, but NO background music.
    Ulead DVD pictureshow lets me make a photo CD with digital stills and background music, but NO short movies.
    Is there an alternate application that allows all 3 that you may recommend?
  2. Argh!!!!
    It's happened again... These are not PhotoCD. These are VCDs where you put photos on it. PhotoCDs are completely something else...
    You can make a VCD with both high resolution stills and video. The video must be encoded as MPEG however. Nothing bar a computer is going to play AVI.
    If you want to author a VCD with both stills and video, your best bet is to use VCDImager +/- a GUI like VCDEasy. Mind you, for more complex projects it will take some time to learn how to do everything and how everything works. The advantage is in that you can do them at all...
    http://www.vcdeasy.org
    http://www.vcdimager.org
    http://www.michaeltam.com
    Best of luck.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Thanks for your quick response. I will repost it as a VCD, NOT a photo CD. :P
  4. Not a problem...
    The only reason I've mentioned it is that those terms have caused some confusion on the board recently...
    Regards.
    Michael Tam
  1. Ideas for home movies DVD background music??
    By Grunberg in forum Authoring (DVD)
    Last Post: 15th Dec 2008, 16:58
  2. How to add background music?
    By coody in forum Audio
    Last Post: 25th Sep 2008, 16:04
  3. help! adding background music
    By Keier in forum Newbie / General discussions
    Last Post: 23rd Jun 2008, 14:30
  4. Replies: 3
    Last Post: 10th Apr 2008, 12:56
  5. How to lower background music
    By auroragb in forum Audio
    Last Post: 24th Jul 2007, 20:54
