Hey all,
got a problem here and I've looked high and low and can't find the answer. I'm using AIW 8500 for capture, SVCD setting, capturing movies from dss. the files look fine when played back, but if you try to edit them, or even "fast forward" using the slider on all of my players, the video freezes and looks like a still frame has had a lot of little square holes cut in it with a different image behind it. The playback counter resumes, and if you leave it alone long enough the video resumes playing(long lag). This makes splitting the movies for SVCD authoring almost impossible. It doesn't happen all the time, but seems to be happening more frequently(?). I've tried defragging before capture, turning things off, but nothing seems to work. Help!!!!!
Results 1 to 1 of 1
You never know how far you can go, until you've gone too far!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
What are Video "Profile Formats" or "Levels"?
By HanDuet in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2011, 23:41 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 18:49
