VideoHelp.com Forum
Thread: vcds and jpgs
  1. I have had great sucess with burning vcd and svcd picture slide shows....but i was wonderting if there is a way to do this and still have access to the jpg files on the same disk so that the people that i send them too can print the picutres????, maybe a mixed mode cd (vcd and data) is this possible....HELP!!!!
    Well, Ulead DVD Picture Show (properly patched) has a check box that, if checked, will create a directory and put all the jpg files in there if you ever want to use them:
    Additonal Archive Bonus Pack:
    - Adds the new Archiving feature
    - With this feature, you can choose to archive your original image files along with your slideshows. Your CD or DVD will contain your slideshows and also give you access to your original image files when run on a PC.
    - To archive your photos, select "Copy Original Image Files to Disc" in the "Determine Output Options Settings" step.
    More at: http://www.ulead.com/tech/dps/dps_ftp.htm
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. Yes you can.
    You can add extra files to the VCD filesystem with both VCDEasy / VCDImager and Nero.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  4. i normally use nero...so you can just create another folder and place them in there?....if so does the location/folder name matter, or is there a specific place that they should go in the current file structure?
  5. You can add them anywhere. I suggest that you create another folder (e.g., "PHOTOS" would be appropriate or "JPEGS" ).
    Don't put the images in one of the existing, default VCD folders or it may cause problems.
    Regards.
    Michael Tam
  1. Sony Vegas Red JPGs on Timeline ?
    By blewyn in forum Editing
    Last Post: 5th Feb 2012, 19:23
  2. minizing artifacts with MEncoder for time lapse from JPGs
    By jon_bondy in forum Video Conversion
    Last Post: 4th Mar 2011, 14:52
  3. SVCD with jpgs and wav
    By gkma01 in forum Authoring (VCD/SVCD)
    Last Post: 28th Aug 2008, 08:03
  4. Phillips 5982 won't display jpgs
    By wannabeswede in forum DVD & Blu-ray Players
    Last Post: 2nd Jan 2008, 07:26
  5. Is there a maximum resolution or size for jpgs imported into Vegas 7?
    By nzo in forum Newbie / General discussions
    Last Post: 8th Oct 2007, 20:18
