I am using VCDEasy to create BIN/CUE files from a mpeg1 file. I get the following error at some point after I hit the GO button:
"VCDxBuild.exe" execution failed:
invalid mpeg packet found at packet# 115060 -- please fix this mpeg file
1) What is wrong?
2) How can I fix this?
Thread: Invalid packet found?
Hi !
If this is your last packet - simply cut it away using MPEGTools from TMPGEnc.
This is only a thought not really a hint but you can try.
Good Luck!
Med.
I don't think that it is the last packet. How do I know if it is the last packet?Originally Posted by Medical
I got a similar problem some time ago.
I have M2-edit Pro. There you can examine your mpeg file.
I found out which timecode the defect packet was and cut it out.
It was inbetween in my video, then. But with M2 you can
perform frame accurate cutting. So it was no problem an no
human being realizes that one frame is missing!
As I said before: I am not sure if this is helpful to you and if
my problem then was similar to your problem now... but as
long as noone else has any suggestions... I would try it!
Med.
can we add null packet to make a CBR h.264 content
By jacopski in forum Video ConversionReplies: 0Last Post: 27th May 2008, 23:55 -
What is packet bitstream and what is it good for?
By chupacabra in forum Newbie / General discussionsReplies: 20Last Post: 25th Sep 2007, 08:13 -
Invalid Location
By Justgrant2009 in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2007, 18:48 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03
Statistics
Newest guides
Latest tool updates
New media comments
