Whats best, open or closed GOP for final mpeg2 for burning to DVD -/+ R?
Thread: Open or closed GOP?
I have no problems with open GOP when I burn DVD-R. They say you should use closed GOP ehen creating multi-angle DVDs or for editing. I have not created any multi-angle DVD but editing is no problem for me. I use M2-Edit Pro 4 without problems and can burn the final result.
The quality is a little bit better with open GOP. Perhaps some DVD authoring programs require closed GOP but I hav never had any problems with SpruceUp.Ronny
I suspected that the quality would be better with open gop's, but wasn't sure. The software I use for cutting out commercials etc from mpeg captures supports cutting on I, P and B frames so if DVD workshop supports open GOP's there is no need for me to create mpegs with closed GOP's.
I need help with open gop i think
By Rathgar in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2012, 15:29 -
MPEG document describing 'open GOP' in detail?
By Alex_ander in forum Video ConversionReplies: 7Last Post: 9th Jun 2008, 13:49 -
Closed GOP
By kitty in forum GlossaryReplies: 1Last Post: 12th Feb 2008, 23:14 -
Extracting Closed Caption and writing it back to mpeg as open caption
By CBiLL in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2007, 02:50 -
Glossery - Error in Closed GOP definition
By SCDVD in forum FeedbackReplies: 0Last Post: 8th May 2007, 18:08
Statistics
Newest guides
Latest tool updates
New media comments
