I need a DVD player that supports 3-5 Disk changer, SVCD, VCD, DVD-R/RW, DVD+R/RW, and Progressive scan. Those are the essentials.
What do you guys suggest?
Philips DVD793CH for $180
http://www.compusa.com/products/prod...ct_code=293545
Sony DVP-NC615B for $180
http://www.compusa.com/products/prod...ct_code=291986
Panasonic DVD-CP67 for $200
http://www.walmart.com/catalog/produ...uct_id=1978021
Sony DVP-NC650V for $200
http://www.bestbuy.com/detail.asp?e=...at=32&scat=244
Probably should take DVD+R and SVCD discs to store to test
Edit by snowmoon to correct annoyingly long URL
I bought the Sony DVP-NC615B for the same reason and found out there are two versions of it. The US model does not play SVCD's. Customizing the SVCD's with the VCD header on them did allow play but makes them non-standard SVCDs and I noticed after a while these non-standard SVCD's would play right in an SVCD player. In summary I would not recommend the Sony. I haven't tested the Panasonic but would tend to guess that one should work.
I bought an Apex 5131 (3-disc changer) a few months ago. it has some drawbacks (lousy remote, a bit loud), but it plays everything i throw at it. However, one caveat: it has recently stopped playing normal DVDs for some reason (it still plays VCDs and SVCDs just fine). I contacted Apex "support" and they were utterly useless in even trying to make a pretense of helping me out.
I don't think those Sony's have progressive scan. Progressive scan is a must.
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Aspect ratio changer for DVD?
By vato76 in forum Authoring (DVD)Replies: 3Last Post: 23rd Jun 2010, 01:29 -
Looking for advice on DVD multi player/changer...
By WuTangMonk in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th Jan 2009, 15:26 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15
