VideoHelp.com Forum
  1. Member scottb721's Avatar
    I tried using TMPGEnc Plus to re-encode an MPEG2 TV capture. I was basically just trying to get the 2Gb movie re-encoded to fit on 2 discs but TMPG kept freezing up during the process.
    The fact that it started encoding at all made me assume I didn't need any plugins.
    It works fine when encoding a DVD2SVCD file.
    Ideas?
    Thanks!
  2. Originally Posted by scottb721
    Ideas?
    Thanks!
    So..are you trying to make a 2 cd ..VCD ?
    "Today is only yesterdays tomorrow"
  3. Member scottb721's Avatar
    Thanks for your time Haggis!
    No, I still want the end result to be SVCD. I just want to lower the bitrate from what it was captured at so it will fit on 2 CDs. I thought TMPG would be good for this.
    I'm also not sure what capture quality I should set my PVR to when doing TV captures. I have plenty of hard drive space so that's not an issue.
  1. Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
    By 2397to2997 in forum Video Conversion
    Last Post: 18th Aug 2010, 15:42
  2. Extract audio from MP2 and more
    By txl in forum Audio
    Last Post: 30th Jul 2009, 06:49
  3. Convert mp2 file in TMPGenc
    By sdlehman in forum Video Conversion
    Last Post: 17th Mar 2008, 16:53
  4. Why MP2? Then why failure?
    By Gripweed in forum SVCD2DVD & VOB2MPG
    Last Post: 22nd Jun 2007, 05:32
  5. Vodai MP2 codec
    By ljs3 in forum ffmpegX general discussion
    Last Post: 9th Jun 2007, 02:38
