VideoHelp.com Forum
    I have searched my entire instruction book for whether or not this Digital camcorder supports pass thru. I have a firewire port and USB port on the Sony and also on my Capture card. Can someone help??
    I am just learning, so be patient with me and some of the questions I might ask.
    Just search on Google for "sony trv-17 pass through" and you get your answer..... yes
  3. It does. The manual calls it digital to analog conversion or some thing like that.
    Esentially you must enable DV out on the camcorder's menu. Plug your VCR to your camcorder. Use a firewire cable (not a USB cable) to your computer's firewire port (if you don't have a firewire port on your computer then buy one with a firewire cable). To capture, you can use Windows Movie Maker or a freeware program called DVIO.
  4. no10ken:
    I just purchased a Sony TRV18. How have your captures from your old analog tapes via the pass-through turned out?
    I'm curious as I am having problems with dropped frames when doing this to my Toshiba laptop via the firewire port.
    What is your configuration for capturing?
    Thanks in advance!
  5. Member SingSing's Avatar
    I think your laptop drive is not fast enough.
    Did you turn on the DMA ?
    I am using Pinnacle Studio Deluxe to capture analog to digital from my VCR, with no problems whatsoever. I do have a 1.9GHZ processor with 120 GB hard drive. I think your laptop is not fast enough to process at firewire speeds, therefore dropping frames. The Sony TRV18 is an awsome camcorder for the money!!!!!
  7. I found my problem!!!
    I disabled Norton AntiVirus auto-protect, and everything was fine. No dropped frames at all, even using Ulead Video Studio 6 with Preview Window on!!!
    Cheers
  1. Sony DCR-TRV18 MiniDV and WinXP Pro SP3
    By zoomie in forum Newbie / General discussions
    Last Post: 30th Aug 2009, 14:31
  2. Replies: 3
    Last Post: 2nd Nov 2008, 14:59
  3. Replies: 3
    Last Post: 30th Sep 2008, 23:18
  4. Wanting to get a Sony DCR-TRV740 camcorder.
    By Undead Sega in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 16th Jun 2008, 19:03
  5. What is the Best MiniDV Camcorder with analog/digital pass-through
    By DigitalGuard in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 20th Jun 2007, 14:18
