OK I have a 734 MB MPEG1 file that I want to burn.
I began with edit/cut it in TMPEGenc. The problem I had there was that after 11 minutes there is no audio in the edited version.
I tried demulti and multiplexing, didnt work. I tried mpg corrector, didnt work either, still same problem.
So I tried VCDEasy but it ignored most of the file.
Under MPEG tools i analysed the file and got the following warnings:
unknown user data tag id 0x65 encountered (not a problem, most likely caused by a specific MPEG encoder)
mpeg scan: pack header code (0x000001ba) expected, but 0x9f081e01 found (buflen = 2324)
bad packet at packet #18967 (stream byte offset 44079308) -- remaining 726580008 bytes of stream will be ignored
The bad packet warning seems to be the problem. Any ideas what I could do to fix the file. It plays perfectly as it is now only it is too big to burn.
Thread: Bad packet ??
I suggest loading the file into Gold Wave, and see if the entire audio is there. If it is, save it as a wave file, and mux it with the original video.
Hello.
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
can we add null packet to make a CBR h.264 content
By jacopski in forum Video ConversionReplies: 0Last Post: 27th May 2008, 23:55 -
What is packet bitstream and what is it good for?
By chupacabra in forum Newbie / General discussionsReplies: 20Last Post: 25th Sep 2007, 08:13 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03
Statistics
Newest guides
Latest tool updates
New media comments
