how do I separate audio from video using virtual dub?
i am trying to change wide screen format to cubic format (to not cut the sides), but when I did it, the audio and video weren't syncronized. i wanna try to separate video and audio, and then put them together.
Thread: video/audio separate
Start Virtualdub. Open your video File->Open video file, ignor the warning
Select under Audio->Full processing mode.
Select Audio->Compression and select <No compression (PCM)>
Select Audio->Conversion. Change the the Sampling rate to 44100Hz
Save the wav by clicking on File->Save WAV
Trying to separate music from the rest of the audio in a video.
By walkerrhodes in forum AudioReplies: 8Last Post: 21st May 2011, 03:18 -
Avidemux: How to separate Video from Audio
By DarkPhoenix77 in forum MacReplies: 1Last Post: 24th May 2010, 02:30 -
Canīt properly separate audio from video
By dexter30 in forum AudioReplies: 2Last Post: 29th Oct 2009, 20:44 -
Use to author from separate audio and video streams?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 14th Jul 2009, 05:41 -
VCRs with separate video/audio tracking?
By Relayerman in forum RestorationReplies: 5Last Post: 12th Nov 2007, 19:52
Statistics
Newest guides
Latest tool updates
New media comments
