also, how do i change the settings so that nero won't attempt to encode the movie.
thnx
If your mpg movie is not in the correct format; frame rate, picture size adn correct audio format, then NERO will give you the OPTION to re-encode your mpeg video to make it compatable with VCD or SVCD format you chose.
I have made VCDs using video already properly encoded without re-encoding.
JDJD tinkerer pushin' 60,
A real Life Enemy of the State, see Fed case #01-40080, Detroit.
Computers, Electronics, vintage Audio, Photography Film/digital/3D, N-Scale RR, ,
AKA the "Infamouse Joe Walker" ,Join the Navy & see (1/2) the world.
Nero attempts to re-encode the movie every time your Mpeg1/2 is non-compliant (not a standard (S)VCD) if Create standard compliant CD is ticked (as per tonyp12's screen capture). To prevent it just untick the box - be warned though that it will create a non-standard (S)VCD which isn't accepted by many players therefore it is better to check beforehand whether your player does. If it doesn't, you need to re-encode your file to a compliant (S)VCD using a proper encoder like TMPGEnc and then burn it with Nero (with Create standard compliant CD ticked). Don't let Nero re-encode to a compliant (S)VCD - that, most likely, will create playback problems.
Originally Posted by tonyp12
I just encode with TMPGEnc,select SVCD,80 Min,select file (drag) & burn. So Tony, yo,what cha doin` with my wife on your posts?
I wish, where``d cho get the hottie?
Encode BD50 movie to BD25 disc - HELP
By kILLDR3n in forum Blu-ray RippingReplies: 9Last Post: 6th Nov 2011, 00:28 -
Can't encode movie at 720 x 576
By zack28 in forum Newbie / General discussionsReplies: 14Last Post: 5th Jul 2011, 17:25 -
how to encode the movie
By yasi in forum ProgrammingReplies: 1Last Post: 7th May 2009, 03:54 -
encode a Keynote Quicktime movie to mpeg2 using ffmpegx possible?
By mkoehler in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2008, 09:16 -
Premiere Pro to Encore DVD. Export movie or Encode?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 04:37
