I am capturing and recording tv episodes to vcd. Captures check. Encoding check. Now that I am coming up with the VCD I'm running into a bit of a dilemma.
I want a VCD with two menus. First menu gives the option to play all or go to menu 2. Menu 2 gives you the option to play a specific episode.
I started by combining the mpegs of 3 episodes into one big mpeg and then laid out the menus using TSCV and chapters. Works pretty well but I notice by the third episode there is an audio lag of a second or so.
What's the disadvantage of using seperate mpeg "tracks", i.e. 3 mpegs per vcd, versus one big mpeg with chapters pointing to each episodes beginnning?
Thread: Tracks VS. Chapters
"Multitrack" VCDs cannot be made to play seamlessly from one track to another. That is the main limitation. If you have SEPARATE episodes (i.e., seamless playback isn't important like it is in chapters of a movie), a multitracked VCD is the way to go...
http://www.vcdimager.org/guides
http://www.vcdimager.org/guides/chapters.html
Regards.Michael Tam
w: Morsels of Evidence
URGENT: Need to output to ASP DivX w/ Multiple Subs, Audio Tracks, Chapters
By Jeet in forum Authoring (DVD)Replies: 0Last Post: 7th Oct 2010, 16:14 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
Issues putting tracks and chapters together
By Smack2k in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Nov 2009, 13:58 -
TMPGEnc AW 4: just 1 menu for chapters in different tracks
By reini in forum Authoring (DVD)Replies: 4Last Post: 25th Mar 2009, 05:17 -
Automating DVD to Divx 6 With All Subtitles, Audio Tracks, Chapters
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 20th Jan 2008, 17:33
Statistics
Newest guides
Latest tool updates
New media comments
