does the quality of cd audio become dodgy at 48000 khz
i am making a video that needs to be exported to dv tape
and want to put music in
but cd audio is 44100 khz and im not sure if it will be affected
very much
advice please
thanks
Thread: urgent--> cd audio on dv tape??
It will be fine if you use a decent quality sample rate converter. Shibatch sample rate comverter (ssrc.exe) is generally considered to of pretty good quality and IIRC is available in the tools section. It can also be integrated within Tmpgenc if that is the encoder you are using.
thanks i downloaded it
but i have no idea how to use it
Its a dos app. Just open a command window, Change directory to wherever you have it stored and type 'ssrc'. It will give you a list of parameters and settings.
[urgent help needed] audio decoding error
By dc0yy in forum Video ConversionReplies: 2Last Post: 26th Aug 2011, 12:47 -
URGENT: Need to output to ASP DivX w/ Multiple Subs, Audio Tracks, Chapters
By Jeet in forum Authoring (DVD)Replies: 0Last Post: 7th Oct 2010, 16:14 -
Please Urgent Canon HV20 Audio Capture Help
By kadzbiz in forum AudioReplies: 3Last Post: 11th Dec 2007, 02:53 -
URGENT: VOB audio issue
By dshefsky in forum Newbie / General discussionsReplies: 4Last Post: 23rd Sep 2007, 05:54 -
Urgent Help! - Panasonic Mini DV NV GS series tape drawer problem
By kwame in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 10th May 2007, 13:28
Statistics
Newest guides
Latest tool updates
New media comments
