I tried to convert a Vob to VCD pal(preset). But i only recieve an m1v bin.(without audio I think).And the message that there will be no audio ?!?
Does anyone know wich option I have to check/uncheck??
Thread: Need help on ffmpeg 4g please.
You should post your terminal output, so as we can try to help you.
OK
Preset is MOV,VOB or DIvx -> VCD(pal)
Here is what the terminal says:
mpeg2dec-0.2.1 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
Using altivec for IDCT transform
Using altivec for motion compensation
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
Frame rate code = 116111
MPEG in libvo = 82224 aspect_code=83496
The result is .m1v! and no audio!!
Choose the audio track number in the "track" dropdown menu of the audio tab, according to which track you've extracted in the VOB.
That`s what I tried first.The terminal ALWAYS shows this after encoding:
0 frames decoded in 0.00 seconds (0.00 fps)
**ERROR: EOF in WAV header
**ERROR: failure reading WAV file
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Volumes/40 Gig/I/I_G.mpg.m1v looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Volumes/40 Gig/I/Ie_G.mpg.mp2 for reading.
I had never demuxed the VOB-stream before using ffmpeg.
Why does ffmpeg seams so?
This error usually happens when selecting the wrong audio track number.
Have you checked off all other tracks and the subtitle tracks in OSEx? If you try to start encoding this VOB to DivX what ffmpegX says about the streams available in the input file?
That`s what I checked first.I also tried to work with a file which is running
with ffmped (version d) some weeks ago and I get the same message.
Do you only get this error with one particular VOB? Are you sure the audio track is in AC3 format?
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum CapturingReplies: 1Last Post: 14th Feb 2012, 04:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 05:09 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
Difference between ffmpeg -threads and ffmpeg-mt
By Calidore in forum Video ConversionReplies: 2Last Post: 7th Mar 2010, 22:44 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
