Wanting to buy a DVD player for my parents for Xmas. Something cheap but reliable that will play CD-R/W and DVD-R. Any decent ones from Walmart, Kmart or Target? thanks
You can try GoVideo 853 available at Radio Shack. Pretty good,
plays mp3, vcd, DVD-ROM, DVD+RW, DVD-RW.
Price is around $70 after rebate. If you want to go cheaper try Apex.
Walmart carrys them.
I bought a GoVideo one.
Shankar.
Walmart had limited supply of the Norcent dp300 for $56. I bought a handful of them for xmas gifts. they play everything ive put in so far. I had to call 8 area walmarts before I finally found a store that had a few in stock
Pioneer 250 - $98 Walmart
Daewoo 5800 - $79 Sams Club
If you are looking for something that supports VCD, be carefull of the Apex line as their latest DVD players do not play VCD (Including the latest version of the AD-1500.) WalMart online (I'm not sure if they would have it at your local store) has a Magnavox MDV450SL for $88.81 at:
http://www.walmart.com/catalog/produ...106168%3A95987
these play just about anything; VCD, SVCD, XVCD (all of Kwag's XVCD templates, although for the K3 you need to change the resolution to 544 X 480), MP3 and JPEG's (just copy to CD and it will display them) on CD-R/CD-RW and DVD-R/DVD-RW formats. It's on the compatibility list (here) at:
http://www.vcdhelp.com/dvdplayers.ph...arch&#comments
For $89 this is a great player. I'm thinking about getting a second one.
go for the sampo's at amazon for 128$us
they got memory card readers....
get a apex ad-1201. it doesn't say it on the box, but it plays vcd and svcd and minidvd
Good/Cheap/Reliable Taiyo Yuden DVD-R sellers in Australia...
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 26th Jun 2009, 02:19 -
Looking for a cheap and good standalone DVD player
By Kweldood in forum DVD & Blu-ray PlayersReplies: 9Last Post: 28th May 2009, 07:54 -
Suggestions for good, RELIABLE player with
By timmus in forum DVD & Blu-ray PlayersReplies: 5Last Post: 16th Nov 2008, 20:58 -
Cheap, reliable ntsc/pal dvd player?
By BIFFtheSTIFF in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Feb 2008, 21:44 -
A good cheap DVD/MP3 player
By NES_Master in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Jun 2007, 02:01
