I can play most of my AVI files. I a couple files that will not play no matter what codec I install. Here is the Technical Info....
The one file is encoded in DIV3 DivX 3 Low-Motion and I have a MPEG-4 Low-Motion installed. When I use Gspot to verify I have the codec installed, it says I do. Now I have looked for and installed DivX 311 yet it still installed a MPEG-4. Yet I still can't play the file. Please help!!!!!!!!
It might be corrupted, have you tried fixing it with Virtual Dub or DivFix?
The file is fine. When I try to install a Nemo Codec Pack, I get the following error messages...
Error Opening file for writing:
"C:\Windows\System32\DivXa32.acm"
"C:\Windows\System32\DivXdec.ax"
Yet all my other AVI files work. Is there a certain codec I need or what?
cannot play avi
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 21:48 -
data avi .hdtv.avi-fqm.wont play on set top recrder
By xbill in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2009, 14:55 -
play AVI on tv
By protectyanek in forum Portable VideoReplies: 4Last Post: 21st Jan 2009, 22:41 -
How to play HD avi files on my tv?
By enchanted in forum Newbie / General discussionsReplies: 4Last Post: 10th Mar 2008, 16:15 -
Cannot play avi?
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 29th Jun 2007, 07:22
Statistics
Newest guides
Latest tool updates
New media comments
