VideoHelp.com Forum
  1. I've take a 40min home video project & burned to dvd.The original MPEG2 file I used plays great on my computer, the burned dvd plays great in my burner on the computer also.The problem occurs on standalone players(and I've tried several).When it plays back if there are any scenes where the camera pans quickly or lots of action occurs the dvd playback is very glitchy,otherwise playback is fine.I'm using the dvd+r format.
    Any advise is greatly appreciated
    Thank you--thepert
  2. Member wulf109's Avatar
    "Glitchy" playback on a standalone is usually a sign of low bitrate. Do you know what bit rate was used to create the .mpg?
  3. The transfer rate I had it set to was 8Mbits/s set at a constant transfer rate.I'm begining to wonder if that is the actual rate I achieved during the encoding process.
    Thank you for responding
  4. Член BJ_M's Avatar
    for compatability -- 8000 is often to high on a lot of media/player combinations -- i suggest a CQ or VBR set at max 6000 - 6800 will often produce better compatibility and even better quality than CBR at 8000 in many cases...
    CBR does NOT mean the bit rate remain constant .. contrary to some beliefs..
  5. Член BJ_M's Avatar
    check it with bitrate viewer also
  6. I'm going to take your advise and burn my next dvd at a lower bitrate and I'll adjust to VBR instead of CBR. I hope this is my answer, I'll let you know how it goes.Thank you for taking the time and effort to help.
    Thepert
    P.S. where do I find a bitrate viewer
  1. DVD Standalone Backups Playback -Not Original DVDs
    By emsdallas in forum DVD & Blu-ray Players
    Last Post: 16th May 2010, 14:11
  2. Xvid AC3 file playback problem on Standalone DVD player
    By kamol88 in forum Video Conversion
    Last Post: 21st Mar 2009, 03:38
  3. MSWMM playback on standalone dvd player
    By theyr961 in forum Newbie / General discussions
    Last Post: 21st Feb 2009, 19:55
  4. Pinnacle 11 - playback issues on DVD - rapid playback problems
    By crven in forum Newbie / General discussions
    Last Post: 15th Dec 2007, 09:19
  5. CD/DVD playback on standalone player is smaller than TV screen...
    By xiduk in forum Newbie / General discussions
    Last Post: 1st Nov 2007, 17:02
