VideoHelp.com Forum
  1. how do you turn video into cartoons
    what filters are there
    Premere or Virtual Dub?
    say I want to shoot footage and make a comedy cartoon after I have captured then what?
    I want the large amounts of solid colors found in cartoons-I am convinced that my wife would look just like Belle in B&B
    If there are no filters that do this are there some good ones for photos and what would I need software wise?
  2. Член BJ_M's Avatar
    you can do this in Softimage XSI (Softimage Toon Shader and Kaydara's Cartoon renderer) , Shake (w/ saphire plug ins) , eyeon Fusion with the 5D plug-ins, toon shader (several for maya) in maya , and a few others..
    (the above options will set you back about $10,000 - $15,000) , nanomation (uk) is working on a cartoon renderer also, (shake and fusion are the best choices with the mentioned plug-ins).
    also you can achieve the same result in other apps maybe (havnt tried it) , reducing number of colors mostly wouldnt work as it would cause severe banding. (to bad you dont have a SGI as there are some apps for IRIX that do this real nice on a SGI.
    but you can get somewhat the same effect (minus the black outline) in tmpgenc or vdub..
    use the smoothing filter (noise filter) and pass the video through a couple of times with the filter set to max or near max .. i would pass it through twice min. (don't encode to mpeg on the first pass with tmpgenc - save it out as avi again) , to get the effect you want you may have to play also with the colours (increase saturation greatly) ...
    good luck !
  1. New cartoon resolution
    By CaZeek in forum Capturing
    Last Post: 18th Oct 2010, 11:22
  2. Should cartoon video be interlaced?
    By indijay in forum ffmpegX general discussion
    Last Post: 20th May 2010, 06:33
  3. Video to Cartoon
    By MarioB in forum Editing
    Last Post: 2nd Nov 2009, 09:30
  4. Creating cartoon video from JPG image
    By richnz in forum Newbie / General discussions
    Last Post: 5th Jan 2009, 15:18
  5. Cartoon Animation
    By dbanga in forum Newbie / General discussions
    Last Post: 19th Jun 2007, 11:46
