I have a slight echo on a avi that I conver to vcd with TMPGenc. The Avi is 1.68 gigs (huffy codec). I captured it using virtualdub and my dazzle usb. I had to leave it at 15 frames per sec, Because if I try a higher frame-rate or a different codec, it gets outta sync. So how do I eliminated the echo from the encoded file? I tried to demux the audio and turn it to a wav but I still get the same results.
Thread: Have echo when I encode.
Have you encoded audio in joint stereo? Try plain stereo instead. It helped me.
echo logfile question
By wiseant in forum ProgrammingReplies: 0Last Post: 17th Sep 2009, 18:42 -
remove echo from vcd?
By sharmine in forum AudioReplies: 1Last Post: 15th Nov 2007, 06:31 -
unwanted echo in a 5.1 channel from a song.
By szarin in forum AudioReplies: 6Last Post: 13th Nov 2007, 11:50 -
Audio echo with new hdtv
By frankhb in forum DVB / HDTVReplies: 2Last Post: 4th Aug 2007, 02:08 -
audio echo during capture
By caveman in forum AudioReplies: 0Last Post: 28th May 2007, 13:09
Statistics
Newest guides
Latest tool updates
New media comments
