VideoHelp.com Forum
  1. In nero when i wantto burn svcd, it gives me the option of ntsc or pal. The video itself is ntsc, but i was wondering, what would happen if i specified pal ini nero to burn an svcd which was actually ntsc.
    If you are only burning SVCD then Nero takes the resolution from the mpeg you are using. The NTSC/PAL selection is only if you are using Nero to encode to SVCD-compatible mpeg (which is not a good idea anyway).
  3. aaaaaaaaaahhhhh, now i get it
    Thanx bhai
  1. when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
    By spiritgumm in forum Video Conversion
    Last Post: 13th Oct 2011, 12:57
  2. How to make DVD in PAL and NTSC?
    By perik in forum Authoring (DVD)
    Last Post: 19th May 2010, 14:18
  3. PAL to NTSC, NTSC to PAL framerate conversion?
    By Baldrick in forum Video Conversion
    Last Post: 5th Dec 2009, 23:31
  4. hdr sr12(NTSC) or hdr sr12e(PAL) any difference between them?
    By deejay.2001 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th Aug 2008, 16:28
  5. NTSC to PAL, PAL to NTSC framerate conversion?
    Last Post: 23rd Apr 2008, 11:19
