Does anyone know if you can "Overburn" and use 90 min CD-Rs with VCDEasy?
Thanks,
CogoSWSDS
Thread: Overburning with VCDEasy
If your burner supports is then yes. VCDeasy imposes very little restrictions on the process.
i agree--i can put 820mb on a 700mb(80mincdr) with vcd easy!
just check enable overburn--if your drive supports it--u can do it!!
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
DVD overburning. Is it possible?
By eroy in forum DVD & Blu-ray WritersReplies: 53Last Post: 6th Sep 2010, 16:57 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
Statistics
Newest guides
Latest tool updates
New media comments
