I have run the file through Virtual Dub to "fix" the file, with no noticable results.
Any other suggestions?
Thread: Slow Seeking on *.avi file
Seeking in .avi files has to do with the CODEC and placement of "key frames"
Generally speaking you can get better compression at the detriment of better seeking since you are including fewer bulky "key frames". Since most things are played straight through many people accept this trade off.
Re-derive keyframe flags? Virtual Dub: File->Open video file...->check Popup extended open options box and load the file, in the Import Options: AVI import filter window check the Re-derive keyframe flags box, press OK. When done save as AVI under new name with Direct Stream Copy selected under both Video and Audio.
That is what I did, but it did not help in the seeking.
I get better (quicker) seeks in Divx Player 2.0 Alpha than in WMP, but it seems that I can seek only to a few (like 4 places) in a 600MB file.
It took VD over an hour to perform the "rederive keyframe flags" action.
Well, then i don't know what else you could do, i wish i could help....
Like snowmoon said - it is a result of compression (people sacrifice the ability to seek in the file for a better compression since they assume the file will be played straight through). If you want to keep it as AVI then i'd suggest getting a new copy (i assume you didn't make it yourself, maybe got it off the net) of different size (preferably larger) unless you will be playing it straight through without stopping. It shouldn't be a problem encoding it to Mpeg1/2 though (i've encoded a few of those and had no problem so far).
how to fix broken avi seeking?
By muffinman123 in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2011, 17:40 -
nandub 1.0rc2 slow seeking
By worm9110 in forum EditingReplies: 1Last Post: 28th Jul 2011, 11:07 -
VOB to .H264 FFmpeg Transcode Bitrate and Slow Seeking
By Gloriosis in forum Video ConversionReplies: 3Last Post: 9th Sep 2009, 14:34 -
Seeking assistance in transfering any video type file to Xbox360 avi
By Peter25 in forum Newbie / General discussionsReplies: 3Last Post: 31st Mar 2009, 19:35 -
Seeking opinions about my converted dv-avi file
By hygieneboy in forum Video ConversionReplies: 35Last Post: 28th Jan 2009, 17:26
