I made 2 short clips from a dvd movie and put them on a VCD, one at 352x240, the second at 720x480. if i encode the whole movie at 720x480, how much bigger will the file size be?
*sighs*
assuming you encoded them both as VCD standard they will be exactly the same size. it is the BITRATE, the number of BITS per second that determine the size of the file. BITS PER SECOND MULTIPLIED BY SECONDS = FILESIZE. see me mention resolution there? and dont even bother doing it at 720x480. it'll look crap, artifacts and blocks.
*sighs* i already burned a test and 720x480 looked great. maybe im just special.
If you maxed out the bitrate to 2600kbps and your video material has little camera movement 720x480 will look good, but if you have a big screen set like me 480x480 at 2600kbps is necessary for everything and looks crappy for high motion material (like sports).
_________________
The last civilization will not be another civilization. It will be that long stretch of realization to which all other civilizations have pointed.- A. Miller
<font size=-1>[ This Message was edited by: tweakybird on 2001-08-21 21:03:07 ]</font>
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44 -
Does a files resolution affect conversion speed?
By perdomot in forum Video ConversionReplies: 4Last Post: 5th Nov 2009, 06:22 -
How much does resolution affect file size?
By milkydoo in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 17:29 -
Converting resolution size
By Illusionist in forum Newbie / General discussionsReplies: 17Last Post: 11th Mar 2008, 01:38 -
How does GOP size affect recording ?
By Serville in forum CapturingReplies: 11Last Post: 17th Dec 2007, 08:02
Statistics
Newest guides
Latest tool updates
New media comments
