Where can i get TDK media 1X or 2X off the net who deliver in the UK or to the UK?? regardless of price,
also what do you think of this media, is it worth all them £££'s
Results 1 to 15 of 15
Thread: TDK media
Branded TDK is very much worth the price. However, beware of the so called unbranded TDK's. They are NOT TDK's and are basically junk.
where can i get some??
i have been using cheap nasty dvd-r's and now i just feed up with the crap that they turn out. Bulpaq and white lable gen4.
So even if you have a place that sells TDK's but not sure if they ship to UK or sell them in the uk post it and i will have a look..
thanks
Go to the first page of this board and do a search using the pricewatch page. TDK's are as low as $3.31 here.
dont ship to uk
Try http://www.121cdr.co.uk or http://www.cd-rmedia.co.uk for sourcing media in the UK.
I have not used TDK because I have had very good results with other, cheaper media. For example, my writer / target DVD player combination really seems to favour the white topped 1x Choice Media DVD-R which you can currently get at the latter of the two addresses listed above.
But they do stock the TDK brand if you want to stick with those.
HTH.
http://www.tigerdirect.com/applicati...p?sku=T14-2062
They are a pretty big store, I've bought from them before, check on international shipping.
Good Luck,
VaBank
can i use dvd authoring disk in a pioneer A04? whats the difference?
No - uses a laser of a different wavelength. The authoring disks usually run 3 - 4 times the cost of a general disk.
Also try http://www.bigpockets.co.uk
My local PCWorld also stock TDK DVD-R and RW media if you want to pay a pound or so more but get them the same day.
wayne16,
I have burned about 20 of these TDK disks. They have worked on every single DVD player I've tested (except Playstation 2).
I'm using Pioneer-104 as well.
va_bank - where u get ur tkds?
wayne16,
The link I posted above will take you directly there. It's tigerdirect.com
10 DVD-R's with jewel cases - $34.99
VaBank
oh yes sorry, didnt realise. tried that place they dont sell internationally.
but thanks anyway.
http://www.blankdiscshop.co.uk/ -- found this site what sell all types of media at low prices in the uk.
TDK Life on Record 4.7GB DVD-R media
By rcvalle in forum MediaReplies: 13Last Post: 15th Dec 2010, 13:21 -
Quality TDK Media?
By hech54 in forum MediaReplies: 15Last Post: 24th Jan 2010, 19:42 -
Magnovox/Funai recorder+ TDK +R media on a Oppo HD970 player= choppy video
By videobruce in forum Authoring (DVD)Replies: 10Last Post: 2nd Nov 2009, 12:40 -
TDK Professional DVD-R media ID?
By lordsmurf in forum MediaReplies: 4Last Post: 15th Dec 2007, 11:08 -
Is TDK's RICOHJPN-D01-67 good Media?
By TBoneit in forum MediaReplies: 2Last Post: 5th Aug 2007, 19:18
