  1. hI I CAN PLAY VCDS ON MY MULTI REGION VCD THE MEDION FINE.
    tHE OTHER DAY I WANTED TO BURN A COPY OF A VCD I HAVE BUT ALTHOUTH IT WROTE IT FINE IT SAID BAD DISC IN THE MACHINE.
    THE CD MEDIA I USED WAS VERBATIM 700MB DISC WITH A BLUE BOTTAM.
    ALSO HOW DO YOU BURN THE 2ND DISC IF IT IS OVER 750MB IN SIZE.?
    THANKS
    JIM
    JIM.G0PRT@NTLWORLD.COM
    One Problem at a time:
    1.) What type of DVD Player (Make and Model) do you have? This way you can check up which media (CD-R, CD-RW, Reflection Layer Colour etc.) it will take.
    2.) Please decribe how you copied the VCD. Did you extract files, or use a Copy CD Software? If so, which program?
    3.) If the 700MB is not enough to place the 750MB VCD file (you should check if the burning program itself will go ahead with the burning, as there is a difference between normal windows file size and what a standard VCD file size is) you can either;
    a) Get a 90+ (850MB) disk if your burner will accept it
    b) Cut the file and burn it to 2 different 700MB disks.
    P.S. I think you will find that if you are making a 1:1 copy from a professional burnt VCD that the disk size is standard, meaning it will fit on your disk
  3. I had problems playing discs with MP3 on the medion 7950 to. When, on advice from a friend, I used 650 MB discs instead, everything worked fine.
  1. Problems copying a VCD
    By muggs in forum Newbie / General discussions
    Last Post: 23rd Feb 2003, 18:59
  2. Playing/Copying .DAT files (VCD discs)
    By patewilliam in forum Software Playing
    Last Post: 20th Oct 2002, 04:09
  3. Problems Copying a VCD onto CD-R
    By wdaly in forum Authoring (VCD/SVCD)
    Last Post: 27th May 2002, 18:30
  4. VCD copying problems using the Roxio! PLEASE HELP!
    By d_sub7 in forum Authoring (VCD/SVCD)
    Last Post: 11th Mar 2002, 07:39
  5. Problems copying VCD
    By src12 in forum Authoring (VCD/SVCD)
    Last Post: 18th Sep 2001, 21:08
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
