Currently, I dont own a DVD burner and I'm making CVD's from Hi8 caps.
Since CVD's are DVD compatible MPEGs I tried burning some of my encodes on CDR (burned as DVD, actually I'm after the DVD menus). It plays well on my PC but cannot on my DVD player.
Is there a way around to make it playable on standalone players?
Very few DVD players are capable of playing MiniDVD.
http://www.vcdhelp.com/minidvd.htm
But are you making MiniDVD/cDVD or CVD
http://www.vcdhelp.com/svcd
My standalone played a mini-DVD (recognised the CD as a DVD), but the playback was stuttering in both video and audio. Probably this is caused by the, for a CD, extremely high bitrate. After all, you expect the player to read a full CD in less than 15 mins - I guess not many players are fitted with readers of that capacity.
/Mats
Remember, a 1x DVD drive (which what a stand-alone player only has to accomplish) can only read a CD at a rate equivalent to about 3x CD (in DVD FAQ).
Most PC DVD-ROM drives speed up when a CD is detected to improve CD read speeds. However, this does not seem to be as common in stand-alone players.
Regards.Michael Tam
w: Morsels of Evidence
...which makes one wonder: At least my stand alone is fitted with an ATAPI interface (or so the firmware page says). How about replacing the DVD drive with a standard PC DVD reader (with better capabilities)? With the DVD reader prices at current level, (in a month or 2 I'll find one in my cereal box!
) that upgrade path is not that longwinded... Anyone who's tried?
/Mats
You're walking in Robshot's footsteps I believe...
There was a guy around about a year or two ago who did a lot of work on miniDVD (not on this forum though). He had an Afreey player that basically had the same problem as yours (i.e., could play miniDVD but there was a max. bitrate limitation problem). According to the articles on his website, the replacement PC DVD-ROM drive worked great!
Unfortunately, I don't think his site is up anymore.
Regards.Michael Tam
I was thinking that it might work - even ought to. There's no reason for DVD manufacturers to fit the stand-alone with non-standard DVD readers (like X-Box), as that would only make things more expensive.
Now, if only I could find a good reason for doing open heart surgery on my stand-alone - maybe "by mistake"
insert a circular abrasive paper...
/Mats
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
I burn a DVD and then when played in a DVD player it cuts off after 50 mins
By uk_rose in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2008, 20:43 -
Gray shade in subtitles when [b]avi[/b] file is played in standalone player
By huRO in forum SubtitleReplies: 2Last Post: 1st May 2008, 14:15 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 12:56
