I got a 640 x 360 .avi file, and I was wondering how i could get it so that it won't be S--T--R--E--T--C--H--E--D out on the TV when I play it.
btw - I use TMPEnc for encoding from avi to mpg.![]()
Results 1 to 9 of 9
Thread: Re-sizing....
And you selected Keep aspect ratio?
Hello.
What's your target framesize in the mpeg?
There's not much to do but then I can't do much anyway.
Yes, I did select "Keep Aspect Ratio", and my target framesize is
320 x 240 for the mpeg.
This movie was originally made in 16:9 widescreen
I found this answer previously posted by user banjazzer
I wonder though about that setting of 320x240. I always use 352x240.The settings in TMPG to use are Source aspect ratio=1:1(VGA) and Video arrange method=Full screen (keep aspect ratio). A widescreen movie will then play with correct aspect ratio, with black bands below and above the movie.
My players would throw a fit if I tried a width of 320.There's not much to do but then I can't do much anyway.
Is there perhaps a step-by-step guide somewhere on doing it, from start to finish, from original AVI to finished mpeg?
If there is, it'd really be a big help.
(sorry for the double-post.)
using 320 instead of 352 leaves room for letterboxing of 16 on both top and bottomOriginally Posted by gll99what are you askin' me for...
I'm an idiot!
fantomlord wrote:
You'll have to explain this one to me?????using 320 instead of 352 leaves room for letterboxing of 16 on both top and bottom
I understand the mechanics of how I could achieve this by shrinking my image and forcing upper and lower bands in the top and bottom dring the resize while maintaining the aspect ratio and so forth......... but.......
Why would I want to do it unless I changed it back to 352x240 and this time did not preserve the aspect ratio? This would introduce a slight distortion but would add those bands you mention. My final target would still be 352x240.
My standalone players and I suspect most others would not accept 320 as a valid w i d t h.
This is posted in the newbie questions and the size of 320x240 I suspect is probably unintended and more than likely an oversight in conversion.
When I have a suspicion about a possible cause , I often try to guide new users in the form of questions instead of always stating the obvious answer.
That's why I asked unknown_1000:
What's your target framesize in the mpeg?There's not much to do but then I can't do much anyway.
320 x 240 is the standard size for television shows. If you select
"Center (Keep Aspect Ratio)" while converting from avi to mpeg, you will create a black "picture frame" around the top, bottom and sides of the movie. This gives your stand-alone DVD player "useless space" to stretch the image, so that it will go full screen, and you won't cut anything off.
Video sizing
By maryhigginsrice in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2011, 20:10 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52 -
avi to mp4 video sizing
By rage777 in forum MacReplies: 7Last Post: 16th Feb 2008, 14:55 -
HD sizing for the net
By zoobie in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 19th Aug 2007, 20:20
