Hi!
I've a question concerning vcdeasy and XVCD.
I know it is possible to create chapters on a normal VCD.
But does it also work with XVCDs?
I aks this because i think the chapters could be not played correctly because of the higher bitrate XVCD's have...
Does anybody know if it's possible?
Thread: create Chapters on XVCD
i've been wanting to know the same thing for weeks. seems as though people don't want to be bothered cuz i haven't received any replies.
Ok, i'll test it on my next VCD i create and will give you the answer...
so long...
Yeah, it works fine!!!
VCDeasy is converting the time you fill in into the required timestamp...even if you take other bitrates than 1150....
how did you do that? everytime i try to add a noncompliant file it tells me that 720x480 is not a valid resolution and it won't let me add it.
now that seems to be a different problem...i only tested it with higher bitrate not higher resolution...
but i can't believe vcdeasy wont let you add mpegs with other resolution.
I will test that too!
thanks. it's because my dvd player doesn't play svcd properly so i make xvcds that are 720x480 at 2400 kb/s. they look perfect but the problem is that i can't get the chapters on them.
Create Chapters with Handbrake
By kinghlg in forum Video ConversionReplies: 0Last Post: 30th Dec 2009, 20:40 -
DVDAuthor can't create chapters?
By Erasmus in forum Authoring (DVD)Replies: 2Last Post: 6th Apr 2009, 12:03 -
How to create chapters for an MKV playable on QT Pro
By VidHunter in forum MacReplies: 0Last Post: 18th Jan 2009, 23:34 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
Use text file to create chapters in DLP
By milway in forum Authoring (DVD)Replies: 4Last Post: 15th May 2008, 20:18
