VideoHelp.com Forum
  1. This is probably an old problem your used to but I have always used other methods of backing up dvd's and decided to venture forth and try out VCD Easy.
    I have XP a p4 2000 and a mitsumi dvd player
    Everytime I start up vcdeasy it works fine until i put in a dvd, or even if i start it up with a dvd in the drive it locks up, I cant shut it down and eventually my pc shuts itself down, I have the latest version and i have tried both aspi's recommended, i have backed up both times so i have been able to return to the beginning, whats going wrong with it?
    VCDEasy does DVDs? I thought it only did CD-R(W)s.
    Hello.
  3. Don't ye worry na more. I figured it out and I'm not going to say what it was so there, however I am impressed at how simple it is.
    You know nothing, you know less than nothing, in fact if you knew that you knew nothing that would be something , but you don't.
    Point Break & carried on to Scrubs by the same actor.
  1. How to lock video files ?
    By altaf in forum Newbie / General discussions
    Last Post: 30th Nov 2011, 15:30
  2. Fraps lock my framerate
    By stranno in forum Capturing
    Last Post: 11th Jun 2011, 17:04
  3. how do i remove an angle lock from a dvd
    By animalia in forum DVD Ripping
    Last Post: 10th Jan 2010, 03:11
  4. why my jvc player is lock ?
    By meeya in forum DVD & Blu-ray Players
    Last Post: 11th Jun 2007, 12:27
