VideoHelp.com Forum
  1. OK, trying to convert our JPG photo's using VCDEasy as per vitualis's suggestion (to show JPG files on our TV through our standalone JVC XV-S500BK DVD player at a faster rate than the disappointing standard slow display rate).
    This error happens when following the VCDEasy Guide for converting JPG's found at: (http://www.vcdeasy.org/modules.php?n...d=SimpleStills)...once I finish the conversion process:
    "ERROR (with a big red circle with white cross) <file name> creation failed malloc failed" then once I close that error box, this info box appears: Mpeg Still(s) creation finished Number of Pictures: 1 Failed: 1 See the log page for details. The log shows the exact above information.
    What am I doing wrong??
    What's a malloc? (Thought it was a Mullet!)
    malloc is a C language function. It allocate memory and it's declared as:
    void *malloc( size_t size );
    size is number of bytes to allocate. The example:
    #include <stdlib.h>
    #include <malloc.h>
    void main( void )
    * char *number; /* that will be pointer for return value*/
    int NoOfBytes;
    NoOfBytes = 1024; /* I want to allocate 1024 bytes*/
    * number = malloc(NoOfBytes);
    * if( number == NULL )
    **** printf( "Not enough memory\n" );
    * else
    printf( "OK, memory allocated\n" );
    malloc will return a pointer to allocated space or NULL it there is not enough memory available.
    So, the application can't reserve a desired portion of memory and picture creation failed. It happen when, obviously, there's not enough free memory but in your particular case, without knowing anything more about your hw/sw configuration, it's difficult to say why this happens.
  1. Replies: 7
    Last Post: 18th Jul 2009, 13:10
  2. svcd preview errors & vob file errors
    By kiwi76 in forum SVCD2DVD & VOB2MPG
    Last Post: 10th Nov 2008, 16:02
  3. FAQ -Common playing problems!
    By Baldrick in forum Software Playing
    Last Post: 28th May 2008, 18:29
  4. DV FAQ - Read me first
    By Baldrick in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 11th Jan 2008, 16:40
  5. check a DVD for errors/read errors?
    By ebob in forum Authoring (DVD)
    Last Post: 5th Jun 2007, 10:53
