  1. I have a 40 file mpg that I want to join. The problem is I have 1-19 then missing 20-30, and have 31-40.
    How can I join 31-40 since I am missing that middle section and HJ split stops at file 19?
  2. Member adam's Avatar
    You might be out of luck. My only suggestion is to join the first series, then rename the last series to 1, 2, etc.. and see if HJsplit will join those. When you have both mpgs use another mpg joiner to join them, TMPGenc will work fine. Thats the problem with HJSplit files, I have no idea why people use that stupid program.
  3. Banned
    I don't see the point, you are missing 1 third of the movie, and its the middle part. Even if you did re-construct it, what use is the movie with the middle missing ?
    Never used that program, But I guess its like the others winrar etc, they have checks, feed them the wrong bit (renamed) and they wont work.
    Best to dump the files and move on....
  1. Missing files
    By justinguitar in forum ffmpegX general discussion
    Last Post: 25th May 2007, 18:40
  2. Missing files?
    By yesfan in forum Authoring (DVD)
    Last Post: 3rd May 2004, 09:15
  3. Am i missing files?
    By sheydel in forum DVD Ripping
    Last Post: 23rd Apr 2003, 12:36
  4. CyberLink PowerVCR QUESTION!!! Split files???
    By aznguy in forum Capturing
    Last Post: 13th Dec 2002, 08:31
  5. HELP!!! Missing audio in newly split MPG (SVCD)
    By duhdrummer in forum Editing
    Last Post: 24th Jun 2002, 00:35
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
