VideoHelp.com Forum
  1. Iīve tried like a million times, I can write the time that the 2'nd chapter should start. then I hit ok, but nothing happens.
    Is there a guide I can follow?
    keep in mind that I donīt have the DVD so I have to write the time of each chapter my self.
    Thanks...
  2. There is one way you could try it, but is very cumbersome and the end result isn't too fantastic but worth the effort is all fails.
    Make every chapter a separate file and for instance use Nero v5.5 to make the chapters.
    The downside is you won't have a fluent transition between chapters, you'll have a delay of about 320 ms, which is possible to see but not very disturbing.
    There are offcourse other ways but this way always works.
    The delay between tracks ( files ) on a (s)VCD is dependant on the player and the authoring software. Both of my DVD player have about a 1-2 second gap between tracks. It's not that bad for TV shows, but for movies it would suck.
    simply use DVD maestro and right click on the chapter line and insert all your times NO PROMLEM dont forget to save or you will be doin it again
  1. Replies: 7
    Last Post: 11th Jun 2009, 01:40
  2. looking for entry level title/chapter/angle info
    By anilty in forum ffmpegX general discussion
    Last Post: 27th Mar 2009, 10:57
  3. Replies: 1
    Last Post: 22nd Feb 2009, 02:25
  4. Replies: 1
    Last Post: 18th May 2008, 11:36
  5. Replies: 2
    Last Post: 4th Feb 2008, 16:26
