Well, When I make a new comp and then import an .avi file into AE
The .avi file is lets say 3 minutes long.
I add a 16mm preset from Cinelook 1.1 film res.
Or, I have also tried applying other effects as well.
The problem is after I add the effect and "make movie" adding it to the render que. I go into render "current settings" because I want to render the entire file, so I have tried altering duration and end so its not just the workspace that gets rendered. I have set it to Full length of Comp, etc. But, when I actually render the file it will only render the workspace!!!
When I change the end of the timecode to match the actual file, then go to adjust duration the end resets back to 9 seconds everytime???????
I cant figure this out. I want to render the whole file not just the workspace. I have tried doing this with both AE 5.0 and AE 5.5 with no luck at all. Does anybody out there please know what I am doing wrong.
Please help me.
Thank you so much for any input.
Ciao
SF
Results 1 to 1 of 1
Thread: Adobe After Effects Problem!
Adobe After Effects Questions
By HoosierGuy in forum EditingReplies: 25Last Post: 2nd May 2011, 21:12 -
Adobe After Effects issue
By Coroni in forum EditingReplies: 3Last Post: 22nd Oct 2010, 20:56 -
Adobe After Effects 7.0 Pro Crashing Problem!
By SciFiGeek17 in forum EditingReplies: 1Last Post: 3rd Jan 2010, 18:01 -
1001 Adobe After Effects Tutorials
By Dennis_H in forum EditingReplies: 2Last Post: 1st May 2009, 21:21 -
problem using youtube avi files in adobe after effects 7
By method in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 23:26
