in vcdeasy, settings my cd-rom shows up, but my cd-rw does not. it's an external plextor cd-rw 40/12/40. anyone have any idea what to do to make it show up in the drop-down box list of writers???
Thanks,
Rich
Try going to "Settings" "VCDEasy" and check the box marked "Enable CDRAO Integration". This should allow you to select your writer under "Settings" "CDRAO".
Thanks - didn't work though. I tried doing what you said, but in the drop-down box, my burner still doesn't appear. It lists my cd-rom, and an old cd-rw that i have installed that doesnt burn anymore. I wonder since it's external and connected to my usb 2.0 port if that has anything to do with it.
One topic is enough.
I seem to remember reading something a while back about USB burners not being usable by CDRDAO. The workaround I'd try is use VCDEasy to make your bin/cue files, then use Daemon Tools (click the "tools link" on the left side of this page) to mount the bin/cue files as a virtual CD-ROM drive and then use the "Copy CD" function of your normal CD-burning program.
CogoSWSDS
I tried to respond to some one else with an external CD-RW problem, but did not see the message post.
Anyhow, try using Nero's wnaspi32.dll
grab it from http://ftp6.nero.com/wnaspi32.dll
copy it over to your CdrDAO subdirectory of your VCDEasy install.
VCDEasy will use that dll over other aspi's that are installed on your machine.
This worked for my firewire drive when I had the same problem with other aspi installs not seeing my external drive.
LAW
Need a new computer - obviously budget-limited (who isn't?)
By magic612 in forum ComputerReplies: 45Last Post: 22nd Jul 2011, 11:19 -
HDTV to DVD isn't 16:9
By sambat in forum Authoring (DVD)Replies: 4Last Post: 6th Apr 2009, 15:54 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 19:45 -
Isn't this annoying?
By Midzuki in forum FeedbackReplies: 17Last Post: 4th Feb 2008, 12:34 -
External drive not showing in Device Manager
By alegator in forum ComputerReplies: 15Last Post: 10th Dec 2007, 12:38
