VideoHelp.com Forum
  1. I have a relatively new Phillips IDE burner that can burn at 8x. I'm trying to burn the bin/cue files which I created from my DVD2SVCD output. . however neither of these proggies can detect the burner because it doesn't use ASPI. .. any ideas? Nero wasn't burning the cue's properly for some reason and so I need another solution.
    Thanks.
  2. Hey. I have exactly the same problem with my AOPen burner. This burner only works with Nero. Tried Adaptec, CDRWIn and Fireburner. Won't work. In case you find a solution, can you e-mail at lino.david@usa.net? We may have different brands but I think it's worth a try.
    I'll do my own research. First stop I think is the manufacturer's website. I'm doing that right now.
    Thanks!
  3. EZ CD Creator works fine for me . . .and I"ll probably use a bin2iso converter. . but I was hoping not to do that. .
  4. You guys may want to try getting a new version of Aspi. It fixed alot of my problems. Since you both have a copy of Adaptec, try looking through the adaptec setup files for an aspi file. Run that, and then go to http://www.roxio.com and get a new upgraded version of Aspi.
    Hope it helps =)
  1. Replies: 7
    Last Post: 18th Nov 2011, 03:16
  2. Looking to get a new IDE burner
    By moonhoney2 in forum DVD & Blu-ray Writers
    Last Post: 29th Oct 2009, 10:23
  3. Pioneer DVR-118L internal IDE Burner ???
    By blinky88 in forum DVD & Blu-ray Writers
    Last Post: 26th Sep 2009, 17:07
  4. ide dvd burner and sata harddrive - how do i configure?
    By mshuang in forum DVD & Blu-ray Writers
    Last Post: 12th Dec 2007, 00:46
  5. IDE DVD Burner VS SATA DVD Burner
    By mn072065 in forum DVD & Blu-ray Writers
    Last Post: 13th Nov 2007, 20:15
