Have read practically every post and found nothing to help my specific problem yet. Have WinDVD2.1 (OEM) and Windows Media Player. Burning VCD and SVCD with Nero 5.5 after encoding with TMPGENC. Play fine on the stand alone DVD player, but can't play on the computer at all. P4 1.4 MHZ Windows ME. I'm going nuts. Have also tried on another cpu with different DVD software. No luck. I have the infamous SCSI1HLP.vxd file mentioned in many posts. Does anyone have any suggestions? I am using the defaults on Nero with the exception of enabling the menus.
Does your SVCD have a SEGMENT folder? If not, WinDVD will not recognise the disc as SVCD.
There is also a patch available to upgrade WinDVD 2.x to version 2.8, find it at this page: http://www.digital-digest.com/dvd/do...wdvd_down.html ("WinDVD XP update"). I am not sure if it will solve your problem.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 05:14 -
WinDVD 9 Plus BlueRay will not play m2ts AVCHD files
By deejay.2001 in forum Software PlayingReplies: 2Last Post: 14th Jul 2008, 08:33 -
Cannot play Blu-Ray in PowerDVD or WinDVD - images are multicoloured snow
By AnitaPeterson in forum Software PlayingReplies: 5Last Post: 17th May 2008, 11:51 -
WMedPlayer WinDVD & VLC will not play video - only audio. Not codec rel
By ligedy in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2007, 02:57
Statistics
Newest guides
Latest tool updates
New media comments
