Waht is the way to speed up rendering process ?![]()
Thread: Hardware acceleration.
The only way to do it that I know of, is to get a Hardware MPEG encoder. Some capture boards have this built on.
P.S.
The only other way to save a "little" time, is to capture at the resolution you will be saving the MPEG as.
I know that Canopus DVstorm is the one but it costs over a 1,000.
I do some editing in Premiere and when you do the rendering it takes a lot of time. I'm looking for something to speedup this process.
You could get a Pinnacle Systems DV500 DVD card it's $650.00
You can check it out here...
http://www.pinnaclesys.com/ProductPa...64&Langue_ID=7
Hope this helps...
Encoders that use gpu acceleration?
By perdomot in forum Video ConversionReplies: 14Last Post: 14th Sep 2011, 10:20 -
cyberlink TV Enhance h.264 hardware acceleration
By jamespoo in forum Software PlayingReplies: 1Last Post: 1st May 2010, 19:24 -
Flash Player 10.1 prerelease with hardware h264 acceleration
By Baldrick in forum Latest Video NewsReplies: 1Last Post: 17th Nov 2009, 06:33 -
Hardware Acceleration and codec help
By mx5 in forum Software PlayingReplies: 11Last Post: 1st Sep 2008, 22:09 -
hardware acceleration for 1080p material, is it needed or not?
By THX-UltraII in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2008, 14:06
