I read the how to, on bin/cue burning on the VCD Easy page and followed everything correctly. My question......and yes I know I will feel stupid when this is answered.Where do I add my bin/cue to allow it to be burned? It will not allow me to do so at the mpeg1 area, so I figure there's another menu I'm missing or I'm misunderstanding something.
Thanks for the help or any direction
Dacru
Thread: bin/cue burning question
Select first your cd writer under S(VCD)->CD Writer.
Now head to Tools -> cdrdao tools and Burn a cue or toc image, open the cue/bin file and burn it.
Thank you very much for the help. I know on the how to section at VCD Easy it says you can turn off the cdrdao tools, so that's what I did, so I think I lost the menu you referred to. When I get home I'll turn it back on and look in the area you talked about.
Once again THANKS !!!!
Darcru
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
Statistics
Newest guides
Latest tool updates
New media comments
