VideoHelp.com Forum
  1. I need a little help with the VCD menus I'm trying to make with VCD
    Easy. So far, every VCD I create works, except for displaying the
    menu when I play it in my standalone player. No problems otherwise,
    themain movie looks great and chapters are perfect. Here's what I currently do to add the menu. I use the MPEG Stills tool in VCD Easy to generate an MPEG from a .JPG file I have. Looks fine, I add it to the list
    (unchecked, right?) and I burn. Like I said, the VCD plays great, but
    every time my menu displays a blank screen rather than the menu image
    from VCD Easy. I know it has burned it because the playback starts
    after 15 seconds which is what I set it to in VCD Easy. Any help with
    this is greatly appreciated. Thanks.
    I've got the same problem and I can't find a solution!!
    PLEASE, HEEELP!!
    Have you checked the comments on your DVD player in the list on this site (DVD Players link on the left)? It's possible that it doesn't support VCD menu stills. I've also heard that getting a newer version of MJPEGTools from the vcdeasy server fixes some people's menu/still problems.
  4. You're absolutely right sterno, thanks. My Pioneer DV-440 wouldn't play the menu stills I created but other DVD players played them just fine. It's a shame because otherwise the DV-440 is a great unit. Thanks for the help.
    A workaround you might try is using tmpgenc to encode your menu image to a single-frame (S)VCD MPG file, I think you'd need to add it as an actual video clip rather than a still. You may have to play with the PBC setup for that clip to make it do exactly what you want, though.
    Thanks everybody!
    I'll try this weekend. I've got the pioneer DV-444. Will post my results.
    Thanks again,
    Martí
  7. I've got a DV-444, and have the same problem too, what I don't understand is...
    if I make a VCD in Nero with it's terrible "simple menus" they display fine (the stills) so my question is, what is the difference between the way in which NERO and EASYVcd make their stills?
    One displays them (nero) and one doesn't (Easy vcd).
    Is there a VCD flag not being set correctly?! just a guess..
  8. Sorry to be annoying, but I'm just bumping this topic back to the top.
  1. Replies: 9
    Last Post: 16th Feb 2012, 18:04
  2. Creating a menu pattern for easy authoring
    By pbear23 in forum Authoring (DVD)
    Last Post: 1st Oct 2008, 22:09
  3. Replies: 4
    Last Post: 28th Jul 2008, 21:57
  4. VCD Easy
    By kshavo in forum Authoring (VCD/SVCD)
    Last Post: 12th Feb 2008, 14:43
  5. DVD Motion Menu Buttons (Free & Easy)
    By ImaWeTodd in forum User guides
    Last Post: 28th Jan 2008, 16:12
