VideoHelp.com Forum
  1. hi everyone,
    I'm just wondering if anybody would hlep me to convert from VCD into tape (VHS).
    I have a wedding film in VCD and I need to put it into VHS.
    how do I do it?
    thanks in advance.
    Dani
    Just run your DVD player through your VCR. When you play it on your DVD, hit record on the VCR.
  3. Thanks for the quick reply.
    the problem I have is that I played my VCD using my PC. I have a Pinnacle DV Plus (capture card) but I don't know wheather I can convert my VCD into VHS tape.
    Please help.....
    Thanks again
    Dani
    Well, you have a few options.
    1. Some Video Cards have video out on them. You could lower your resolution and play full screen and record from there.
    2. Get a analog capture card or upgrade to a card that has both... and follow step 1.
    3. Get a DVD player you can hook to a VCR. They are getting very cheap, about $100.00 or less can get you one that will play anything.
    (Look at the RCA 5240p - $99.00)
    4. Take the CD to a friend who has a DVD and VCR hooked up, and transfer it there.
    Thats about all I can think of right now... Good Luck!
  5. hello again,
    I really appriciate your help.
    is there any software that converts the file?
    by the way the file is *.dat.
    if you know a software that can convert it into avi, it would be great.
    cheers!
    Dani
    Not sure why you would want to do that... but check this out...
    http://www.vcdhelp.com/forum/viewtop...onvert+dat+avi
  7. Fantastic!
    Thanks heaps!!!!!!
    Dani
  1. Replies: 49
    Last Post: 8th Dec 2010, 11:34
  2. HDTV VCR recording, VHS TAPE?
    By jb66 in forum Newbie / General discussions
    Last Post: 22nd Oct 2008, 17:45
  3. What is the exact physical point where recording happens vcr and a tape ?
    By arturock in forum Newbie / General discussions
    Last Post: 9th Sep 2008, 21:15
  4. Recording a NTSC VHS Tape with a PAL DVD Recorder??
    By Lanno in forum DVD & Blu-ray Recorders
    Last Post: 5th Sep 2007, 03:42
  5. Urgent Help! - Panasonic Mini DV NV GS series tape drawer problem
    By kwame in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 10th May 2007, 13:28
