Alright,
Last night I burnt a bin/cue file with CDRwin, did open cuesheet, and did start recording. The cuesheet called for three files to be burnt, 2 smaller files and the movie! Ok, well I try out the CD, my Apex DVD player reads it and can tell that there are 3 tracks (files), but it will not play the movie!! How can I get the movie to play? Please help! thanks
If this helps, the movie was The Others - unrared it got a bin and cue file!
when you unrared it did it have any problems? I am assuming you downloaded the file? You could use vcdgear to get the mpg from the bin file to make sure it works and that, that isn't your prob.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
Statistics
Newest guides
Latest tool updates
New media comments
