VideoHelp.com Forum
  1. Banned
    can anyone help!!
    i have burned some dvd-r discs but on play back the picture becomes all broken up and the sound cracks then the picture will freeze and the only way to get things started again is to switch off my dvd player.it seems to happen after about an hour or so into the burned movie.is this an hardware problem or is it something i,m not doing properly.this has happened on most of the discs i,ve done so far.
    i,m using claddvd xp,tmpegenc and dvdit pe to copy my dvds to.
    any ideas on how i can rectify this problem
    del
  2. sounds like you're using poor quality discs, they usually play fine at the beginning then break up as you get further into the film, try some better quality media
  1. Breakup a huge mkv file into smaller pieces
    By mysts in forum Video Conversion
    Last Post: 3rd May 2009, 14:34
  2. video breakup and glitch detection software
    By Zone3 in forum Newbie / General discussions
    Last Post: 16th Feb 2009, 21:22
  3. Replies: 8
    Last Post: 8th Oct 2008, 21:53
  4. Is it possible to rip a HD DVD disc to Hard Disc ?
    By fjmr in forum Newbie / General discussions
    Last Post: 13th Sep 2007, 12:50
  5. Audio Breakup
    By Sooner02 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 23rd May 2007, 11:47
