VideoHelp.com Forum
  1. Apache Umen Pich's Avatar
    I have a Philips DVD 623.
    After a week of experiments , making different VCDs and SVCDs I think it cannot play variable bitrate properly.
    It stops every 5 seconds or so, for part of the second.
    The same clips if encoded with CBR are OK.
    Do you have the same player and is this problem common at all. I tryed to search for previous discussion on that topic, but found nothing.
    thank you
    Best wishes,
    UP
    What VBR settings? What input video? What template?
  3. Apache Umen Pich's Avatar
    Well, I think just any settings. I didn't make all the possible experiments, but it seems so. Does it sound strange. Maybe that particular machine is not OK.
    For example the standart template for NTSC VCD, modifyed to have VBR. Or the template for SVCD. Damn player !
    Best wishes,
    UP
    What I'm asking is what did you use for MIX, MAX and average bitrate.
    If your bitrate goes too high it will cause the DVD player to choke for a second every now and then. If you are converting from some AVI off the internet it's possible that the .avi file is not NTSC 29.97 framerate. Some DVD players cannot take video bitrate going below 500kbps.
    That's why knowing the settings are important.
  5. Apache Umen Pich's Avatar
    It was not too high. It was too low. 300kbps. Now tryed with 700kbps minimum and it works. Maybe the limit is really 500kbps. But this is not mentioned in the manual (which is like most manuals for idiots - push the start button to start and so on
    Best wishes,
    UP
  1. Need help to set up Variable Bitrate
    By spigy in forum Video Conversion
    Last Post: 16th May 2010, 13:13
  2. Variable Bitrate or Constant Bitrate?
    By i am x in forum Video Conversion
    Last Post: 12th Feb 2010, 07:49
  3. VBR (Variable Bitrate) WMV file to avi conversion process problem...
    By Atakanbasturk in forum Newbie / General discussions
    Last Post: 31st Oct 2009, 16:44
  4. Variable bitrate Mpeg-2
    By miggeth in forum Newbie / General discussions
    Last Post: 23rd Jun 2008, 07:58
  5. Variable and Constant bitrate ??
    By VEBouto in forum Newbie / General discussions
    Last Post: 17th Oct 2007, 23:56
