First I want to request excuses by my English, I am Spanish.
With the lastest version of VCDEasy I have tried to record my MPGs in PAL format and although I have all the options put for the PAL, it only create cds in NTSC format. Therefore I can't play with my DVD Player. In other Dvd Player the movie play quickly.
It is a configuration problem or it's possible bug?
Thanks and a greeting
Thread: I can't burn in PAL format
What do you use to encode the mpeg? This may be the problem. I only use PAL, and have had no problems like this. The tools I use are TMPGEnc and VCDEasy.
Just make sure that all of the options from the encoding stage to the burnign stage are in PAL and it should be OK. Hope this helps.
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
I need PAL format help...
By jenn00_v in forum Newbie / General discussionsReplies: 15Last Post: 26th May 2009, 16:29 -
Burn to 16:9 format
By ozab in forum Video ConversionReplies: 11Last Post: 10th May 2009, 16:29 -
Any S/W Players that will play PAL format clips ?
By Seeker47 in forum Software PlayingReplies: 2Last Post: 17th Sep 2007, 14:10 -
Actual format PAL??
By KingBongo in forum ffmpegX general discussionReplies: 5Last Post: 11th Jun 2007, 06:29
Statistics
Newest guides
Latest tool updates
New media comments
