For a 6 minute video clip (vhs to tv capture card), I'm losing around 64 frames. Is this acceptable? Sometimes the audio wont match the video (cars burning their tires etc...). I use a Savage S3 2000 Video card (64mb) and onboard audio. What is this DMA Enabled stuff I hear about?
Thread: Frame dropping question
Guest
How many total frames have you captured when you dropped 64 of them? What program were you using?
Hello.
Guest9000 frames total. 64 dropped
Im using Sonic Foundry Vegas Studio.
Not necessarily. If you are satisfied with the results. If you think you should be doing better, you may want to check to see it your hard drive is DMA enabled by going to device manager.
Also, capturing can be improved by using two hard drives, one for your programs, the other for the captured file. You may also make sure you are doing nothing on your computer during the capture, except of course, capturing, ensuring only the capture program is the only one running.Hello.
DVD frame dropping.
By videosam in forum Video ConversionReplies: 20Last Post: 4th Aug 2010, 04:00 -
Dropping one single frame in a two hour capture?
By justin81 in forum CapturingReplies: 5Last Post: 13th May 2010, 09:38 -
Flickering / Fluttering / Frame dropping...is this copy protection??
By mik534 in forum DVD RippingReplies: 9Last Post: 2nd Oct 2009, 06:55 -
Dropping frame with profile H.264
By n69 in forum Video StreamingReplies: 2Last Post: 22nd Dec 2008, 21:41 -
is this pinnacle, dazzle or my new PC causing my frame dropping problems
By arthur1971 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2007, 02:41
