VideoHelp.com Forum
  1. I have an Apex 1500 and it can’t load VCD and SVCD I burned with Nero, tried many times still no luck Here are the detailed steps of last try, would appreciate for any help.
    -Use pinnacle PCTV to capture videos from digit camcorder to AVI files, file size 2.5 GB.
    -Use TMPGEnc Plus 2.51.33.127 to convert AVI to Super VCD NTSC, file size over 1GB
    -Use TMPGEnc Plus to cut MPG file into 700m, choose type MPEG-2 Super VideoCD (VBR), able to play in computer
    -Use Nero 5.5.9.9 express wizard to create Super VideoCD, selected ISO9660 and 8.3 file format, disable Joliett
    -Not sure if I have SVCD plugin, the downloaded Nero 5.5.9.9 is about 12.1 MB, anyway it allows me to burn SVCD
    -Notice after adding source file the size is only slightly over 600m
    -Successfully Burn SVCD, use Samsung 24x burner, Victor 32x 700mb 80min CD-R
    -Put into Apex 1500, only shows “load”, also can’t play in computer.
    Btw, I burned MP3 using Nero, Samsung burner and Victor CD-R before and it plays in Apex 1500.
  2. very odd that it wont play in your computer if it doesnt play in your computuer it woint play in apex... apex is mostly computer parts.... make sure you just use the default template in tmpengc for vcd or svcd then use the svcd or vcd tempolate in nero, dont change any of the settings in either except bitrate or filesize in the encoder... ive converted a bunch of avis and they all work in my apex's.
  3. Thanks for your reply. After searching around I can play svcd cd in my computer using powerdvd, but still can't play in apex 1500. What software and what setting you use to burn svcds
  4. Try VCDEasy, it solved all my problems..
    http://www.vcdeasy.org/
  1. Adobe Premier 5 AVI's won't load into Nero Vision 10
    By rlarden in forum Video Conversion
    Last Post: 2nd Jul 2011, 04:43
  2. Philips DVP-5990 Won't Load Some Burned DL Disks
    By wulf109 in forum DVD & Blu-ray Players
    Last Post: 28th Jan 2010, 14:26
  3. Replacement for Apex AD-1500
    By siskiou in forum DVD & Blu-ray Players
    Last Post: 30th Mar 2008, 22:59
  4. Cannot read Nero-burned CDR (Vista) on XP
    By walter4h in forum Computer
    Last Post: 27th Mar 2008, 01:20
  5. Burned my first divx using Nero but they are not in sync
    By Taylor in forum Newbie / General discussions
    Last Post: 3rd Sep 2007, 23:07
